I have passed AI-900 exam using certiport but My certificate print do not show certificate number. How can I retrieve certificate with certificate number ?
AI-900 certificate print do not have certificate number
Hello, Vijay!
Based on your inquiry, we understand that you want to get your certificate obtained with Certiport Microsoft Certified: Azure AI Fundamentals in your account. We are happy to help you!
We want to let you know that since the certification was obtained with Certiport, to get your certificate it is necessary to access via Certiport system.
We understand how important it is to add the certificate you got with Certiport in your certification profile to visualize it ; however, we require informing you that temporarily it will be necessary that you use both MS Learn and Certiport platforms to access your Certificates.
Our Microsoft Credentials team is currently working to improve the overall integration of Certiport and Microsoft credentials records. As a result of this work, we are temporarily unable to populate Certiport-earned certifications into Microsoft Learn profiles or merge Certiport and Microsoft Learn profile contents.
Please refer to the approved message we received from our Engineers Team:
“Our Microsoft Credentials team is currently working to improve the overall integration of Certiport and Microsoft credentials records. As a result of this work, we are temporarily unable to populate Certiport-earned certifications into Microsoft Learn profiles or merge Certiport and Microsoft Learn profile contents. We expect to complete our integration work in the coming months, at which time your Learn record will reflect all your Microsoft Certification activity.
In the meantime, please be aware that you are still able to manage your Certiport-earned certifications from your Certiport Test Candidate account where you can view and download and share your certificates and your Certiport transcript. We apologize for any inconvenience.”
If you are not able to access to Certiport to get your certificate, it is necessary to contact Certiport so they can help you with the process:
In the meantime, we recommend you access to your certificate via Certiport using the following link: Print certificates and score reports :: Become a test center :: Educator resources :: Certiport (pearsonvue.com)
We appreciate your understanding of this situation. Thank you again for your patience.
This being confirmed, for the moment there are no actions pending from our end. We are sorry for any inconvenience caused.
Please let us know if there is anything else we can do for you. In case we do not receive a response, this case will be closed and locked after one business day.
Have a wonderful day,
Hello, Vijay!
Since we have not received a response from you, we will proceed in closing and locking this case. If you still require assistance, please post a new question. We will be happy to jump in and take a look.
Wishing you the best,
Last updated June 18, 2024 Views 37 Applies to:
