Azure Solution Architect Expert Badge
I have successfully passed AZ-305: Designing Microsoft Azure Infrastructure Solutions. I see the certificate on my Microsoft certification dashboard , but I can not find the badge on Credly it only shows my other certification badges. Cloud you please help me with it.
Hello, Sikander!
Based on your inquiry, we understand you are unable to visualize your badge for Microsoft Certified: Azure Solutions Architect Expert. We are happy to help you.
Please note that Microsoft has ended their partnership with Credly on June 30. This means that the badging services provided by Credly no longer apply for most of Microsoft Certifications (excepting certificates obtained via Certiport). Our new scheme has changed from 'Badge sharing-based' to a 'Certification shared-based' scheme.
What is shared from your Learn Profile is the certification itself. We will provide the steps of this new experience so you can share your Certificate to the available social media platforms. Kindly follow the next steps to share your certificate:
  1. Sign into your Learn profile.
  2. Click on the photo avatar and select Profile from the dropdown menu.
  3. Select Certifications from the menu inside your profile.
  4. If you want others to be able to verify your shared certification, set your Learn profile view to public
  5. Scroll to the certification that you’d like to access and select “View certification details” below the description.
  6. Under the certification title, there are three options: “Print”, “Edit display name” and “Share.
  7. If you’d like to share your certification, select “Share.” Select the location to which you want to share your certification.
With this being confirmed, our badges sharing article information has been updated with all of the necessary details regarding the new Microsoft Certification sharing experience:
For additional information regarding the changes on our platform, please refer to the link below:
If you are not able to share or visualize your certificates Microsoft Certified: Azure Solutions Architect Expert using this information and steps, please let us know and we will open a Private Message to provide you with our best solution.
If no additional assistance is required, please indicate “Yes” to the question and the thread will automatically be closed and locked. In case we do not receive a response, it will be closed and locked after one business day.
Tatiana Valencia.
I am able to see the certificate as I already mentioned in my prior message, I need a badge to add to my email signature, I understand now I can share my certificate but how can I add in to my email signature? I need help with that.
Hello, Sikander!
Thank you for your response, we appreciate it.
Please note that Microsoft has ended their partnership with Credly on June 30. Our new scheme has changed from 'Badge sharing-based' to a 'Certification shared-based' scheme. Here's what this means to the candidates:
  • From that date, Credly will no longer issue badges for Microsoft Certifications.
  • All your badgess will be on your Microsoft Learn profile, ready for sharing and verification, and will be updated with pertinent information, such as expiration and renewal dates.
  • If you don’t have a Credly profile, you can verify and share your certifications on your Microsoft Learn profile.
  • If you do have a Credly profile, Microsoft Certifications that you earned and claimed before June 2023 will be there through June 2024, but will no longer be updated with changes to expiration or renewal dates.
  • If you’ve shared your certifications through Credly on other platforms, such as LinkedIn, we encourage you to share them again from your Microsoft Learn profile to help ensure continued verification services, since Credly will no longer verify or receive any information on Microsoft Certifications after the end of June 2023.
With that information said, the option to attach the badge to the e-mail signature (Can I attach my badge to my email signature? – Credly, Inc) is no longer available because the badge will not be issued for any certificate (You can share your certifications via Email, Twitter, LinkedIn, and Facebook. You can also generate a unique link from your Learn profile. Simply select “Certifications” in your profile, select the certification you would like to share, and click the “Share” link).
In this case you can share your certificate itself with the new sharing options on your Learn Profile (what is going to be shared is the certificate).
Kindly follow the next steps to share your certificate (at this moment this is the sharing experience available):
We invite you to check the article information with the necessary details regarding the new Microsoft Certification sharing experience and the current options to share:
Warm regards,
Tatiana Valencia.
Hello, Sikander!
Since we have not received a response from you, we will proceed in closing and locking this case. If you still require assistance, please post a new question. We will be happy to jump in and take a look.
Wishing you all the best,
Tatiana Valencia.
Last updated August 8, 2024 Views 309 Applies to:
