Connectivity Issue: "Setting up copilot Studio" Time out error
Hi, My test will not load the web app (copilot studio). I have tried twice and both times it just hangs.
Microsoft Applied Skills: Create agents in Microsoft Copilot Studio
Now only 1.17mins left in test. Image attached. I have to go home now and don't want to wait for 72 hours before I "retake" it...
Browser used: Edge
Test code: 51858174
Please advise???
Thanks,
Nick
Hi Nick,
I recognize the importance of successfully completing the applied skills without any complications. Please be assured that I am here to assist you in navigating this challenge and finding an appropriate solution.
We have reviewed your assessment lab, and it appears that the issue you encountered was transient, meaning that we can’t replicate it. However, it is extremely unlikely to happen in the future unless there is something about your setup that could be inadvertently playing a role. Please make sure that you review the Assessment Lab System Readiness requirements and take advantage of the Speed Test and Lab Orientation and Connectivity Check tools available on our FAQ page.
Meanwhile, if you happen to retake the assessment and encounter the same error, despite meeting the requirements, kindly provide the following essential information below:
  • Title of the Assessment
  • Lab Instance ID:
    (This can be found in the Instructions tab of the lab. If you have launched the assessment, this is found in the instructions tab under "Troubleshooting").
  • URL: (Copy the entire URL of the problematic page and paste it in your response).
  • Date/Time you encountered the issue:
  • Description: Explain the primary issue:
Once we receive these details, we’ll be able to forward them to our Support team for further investigation and to explore potential solutions and recommendations. We appreciate your patience and cooperation.
I look forward to your response. Please note that if no response is received after three business days, the case will be closed and locked. After the case is locked, we will no longer be able to respond. Thank you.
With appreciation,
Michael_B07
Hi Nick,
I hope you are doing well.
I wanted to follow up with you if you were able to take the lab again and if further assistance is needed.
Meanwhile, as we hear more about the issues our learners are facing, we have discovered that most performance-related problems can be resolved by ensuring the computer meets system requirements and has sufficient bandwidth. If your system and bandwidth meet the minimum requirements and you still experience issues, the problem may be transient and hard to reproduce with the information provided. If the issue persists, please gather the following information to help us investigate further:
In addition, please also consider trying the following troubleshooting steps:
  • Refresh your browser and ensure it is up to date.
  • Continue to use Microsoft Edge as your browser, if possible.
  • Clear your browser’s cache and cookies.
  • Enable all third-party cookies in your browser settings.
  • If you're using a work device, consider switching to a personal computer, as work machines may have restrictions that block access to certain websites.
Furthermore, the 72-hour retake waiting period is triggered when an assessment lab ends for any reason after the "Start Assessment" button is pressed. Retake waiting periods are common practice in the credentialing industry to provide learners with study time in between attempts and to ensure that as many users as possible have access to limited lab resources. However, we recognize that this policy has unintended impacts for learners whose labs ended while still in progress. We are evaluating other strategies for managing this policy. We apologize for the inconvenience and hope that you attempt your lab again once the retake waiting period has passed.
Warmly,
Jai_T4
Hi Nick,
We have not received any update from you. This case will now be locked. If you need further assistance, please post a new question.
Warmly,
Jai_T4
Last updated June 13, 2025 Views 101 Applies to:
