As per the header, the Lab interface is very very small, it was difficult to scroll down and up.
Also, the SearchAI key is missing as well and seems due to the screen it was difficult to locate the Primary Admin or Secondary Admin keys.
Please let me know once its resolved.
Develop Generative AI Solution with Azure Open AI Services. - Applied Skills - The lab screen, and not able to find the Search AI Keys
You need a decent sized screen and screen resolution to take an applied skill as you are accessing a desktop within a browser.
You can switch the lab interface into full screen to assist you
See Assessment lab frequently asked questions | Microsoft Learn
Hi Mohan,
I understand that you have encountered an issue with your Applied Skills Assessment. Allow me to assist you by providing you with further details to resolve your issue promptly.
@Julian, thank you for your insights. If you are taking an Applied Skills assessment, please note that while you can adjust the lab's resolution, size, and screen layout, and even turn off the scroll bar, full-screen display is not available.
If the VM inside the lab is too small, or if the resolution is too low, please note that the default resolution setting for the VMs is 1024 x 768. You are likely launching at a lower resolution. Increasing your resolution to the default or higher should resolve the issue.
Furthermore, you may also utlize this Assessment lab frequently asked questions | Microsoft Learn for detailed information regarding the Display Menu.
Should you need further information or clarifications, please feel free to let us know and I'll be more than happy to assist you.
I look forward to your response. Please note that if no response is received after three business days, the case will be closed and locked. After the case is locked, we will no longer be able to respond, even through Private Messages. Thank you.
Warm Regards,
Hi Mohan,
I hope you are doing well.
As our main goal is to ensure that we got you well guided, I am sending you a follow up response to confirm if you require any additional assistance, please feel free to let us know and I'll be more than happy to assist you.
Otherwise, if this solves your problem, please indicate “Yes” to the question and the thread will automatically be closed and locked. In case we do not receive a response, the thread will be closed and locked after three business days. Please be advised that after the case is locked, we will no longer be able to respond, even through Private Messages. If the resolution provided did not resolve the issue, please post a new question.
Warm Regards,
Hi Mohan,
Warm Regards,
Last updated November 7, 2024 Views 61 Applies to:
