Hello, I just passed the Data Engineering on Microsoft Azure exam (DP - 203) ********** and I do not know how long I will have to wait until the Certificate (Microsoft certification ID: *******) will be available on Credentials tab, so I can share it on other platforms. Can you please let me know?
How long after I passed Data Engineering on Microsoft Azure exam (DP - 203) the Certificate will be available on Credentials tab?
Hello, Lungu Ioana.
Thanks for reaching out to Microsoft Community.
Validating your request, we understand you are unable to see your Azure Data Engineer Associate Certificate on your Profile. We are glad to assist you!
Please note that the certification process takes 48 hours, and this information will be visible on your Profile. However, we will also conduct an investigation of your Profile.
For additional support, we have initiated a private message requesting specific information related to your needs. Our goal is to verify the details and offer personalized assistance. You can access the link provided in the message.
-Private Messages - Microsoft Community
We are looking forward to your information. If no response is received within two (2) business days, we will proceed to close and lock this case as well as the Private Message.
Hello, Lungu Ioana.
Thank you for your reply.
We are carefully examining all the details you have given us to provide you with the optimal solution. We left a detailed response over Private Message, please refer to it and let us know if you want us to assist you with the indicated process:
Hello, Lungu Ioana.
Thank you for all the information you kindly provided.
Your case was successfully assigned to our Team in charge of further review and assistance to proceed with the merge. Once we have an update regarding the progress of your case, we will get back to keeping you posted.
Please bear in mind that it might take from 3 to 5 business days to provide you with further updates.
We will be attentive to your comments.
Hello, Lungu Ioana.
Thank you for your patience.
Our team is now handling your case for additional examination and support. We will keep you informed once there is progress.
Please bear in mind that it might take 3 to 5 business days to provide you with further updates.
Wish you the best,
Hello, Lungu Ioana.
We want to notify you that your profiles have been successfully combined. Please review the details of your primary Certification Profile, which we sent you via Private Message, and ensure that your account is functioning correctly.
We trust this information is helpful to you. If you require any further assistance, please don’t hesitate to reach out.
We appreciate you feedback about your support experience, so we kindly invite you to indicate "Yes" where it says, "Did this solve your problem"? located in the bottom right corner of the thread and will automatically be closed and locked.
In case we do not receive a response, it will be closed and locked after one (1) business day.
Hello, Lungu Ioana.
We hope you find this message well.
We would like to know if the solution provided solved your inquiry and if additional assistance is needed. Otherwise, we will proceed to close and lock the case within the next business day.
Hello, Lungu Ioana.
We trust that everything is proceeding well for you.
Unfortunately, we did not receive a response from you within the anticipated timeframe. Consequently, we will proceed to close and locked this case. Please be aware that once this thread is closed and locked, you will be unable to reply via this channel.
If you need further assistance regarding your Microsoft's Certification Profile, you can easily reach out to us by a new question or start a discussion (microsoft.com), and we will be delighted to assist you with any inquiries related to Microsoft Certificated Professional.
We appreciate you feedback about your support experience, so we kindly invite you to indicate "Yes" where it says, "Did this solve your problem"? located in the bottom right corner of the thread.
Warm regards,
Last updated June 20, 2024 Views 213 Applies to:
