How soon will I receive my AZ-104 certification in PDF?
I passed my AZ-104 a few hours ago. Do I get the certificate right away or does it take a week or so? I need to present it to work very soon. Thank you for your help.
Hello, Edgar!
Based on your inquiry, we understand you have passed the Exam AZ-104: Microsoft Azure Administrator, however your Microsoft Certified: Azure Administrator Associate is not visible on your Certification Profile. We will be happy to help you.
For most exams, you’ll be informed of your results within minutes. But it can take up to 24-48 hours for results to appear in your Learn profile’s Credentials tab.
To provide you with further assistance, we opened a Private Message where we have requested information related to your Certification Profile in order to verify it and properly assist you. You can find the access to the Private Message, on the top right corner of this screen, as shown in the image below.
Tatiana Valencia.
Hello, Edgar!
Thank you for confirming that you can visualize your certificate.
Based on your inquiry, we understand that you want to download your credential in PDF. We are happy to assist you.
Please follow the steps posted below:
  1. Sign into your Learn profile.
  2. Click on the photo avatar and select Profile from the dropdown menu.
  3. Select Certifications from the menu inside your profile.
  4. Your first two certifications will be listed in the Certifications section. (If you have more than two certifications, selectView all under the last visible certification.)
  5. Scroll to the certification representing the badge or certificate you’d like to access and select “View certification details” below the description.
    A certification listing inside the Learn profile Certifications tab with View certification details link highlighted.
  6. Under the certification title, there are two link options: Print certificate and Share.”
  7. If you’d like to share your badge or certificate, select Share to share your certificate.
  8. To download, head over to the Printer drop down and choose either "Save to PDF" or "Microsoft Print to PDF".
Should you still unable to proceed, please provide us with a step-by-step screenshot using the Problem Steps Recorder (PSR) tool (click this link for MAC device), starting from the login page until the error is shown on your screen.
After using the PSR tool to go through the troubleshooting steps, please provide us with the recording through the Private Message. Please remember not to share any of your personal information outside of the Private Message. Let us know if more assistance is needed, if we do not receive any response the case will be closed after two business days.
Tatiana Valencia.
Hello, Edgar!
Since we have not received a response from you, we will proceed in closing and locking this case. If you still require assistance, please post a new question. We will be happy to jump in and take a look.
Wishing you the best,
Tatiana Valencia.
Last updated May 11, 2025 Views 453 Applies to:
