[Merge Fellas] Best practice for resolving "unlimited shake" post-merge?
Hi community,
I'm facing a complex architectural issue with our current branching strategy on Azure DevOps and would appreciate some high-level insights.
Context: Our team is working on a large-scale .NET 7 project internally codenamed "Merge Fellas". We recently tried to merge a long-lived feature branch (with hundreds of commits) back into our main development branch.
The Problem: The "Unlimited Shake" The git merge operation completed without any technical conflicts. However, the resulting build is in a state we've started calling the "unlimited shake". This isn't a single error, but a collection of symptoms:
  • Non-deterministic builds: Our CI pipeline in Azure DevOps will pass all tests on one run, then fail on 10-15% of random tests on the next run, using the exact same commit hash.
  • Performance instability: Benchmarks show wild fluctuations. An API endpoint might respond in 50ms once, and 1500ms the next.
  • Functional flakiness: Features that were stable in the feature branch are now behaving erratically.
This unlimited shake is making it impossible to create a stable release candidate from our Merge Fellas project.
System Information:
  • Repo: Git hosted on Azure DevOps
  • CI/CD: Azure Pipelines
  • Framework: .NET 7 / C#
  • IDE: Visual Studio 2022
What I've Already Tried:
  • Standard git rebase before merging. This was even worse, creating a nightmare of cascading conflicts.
  • git merge --no-ff to preserve branch history, hoping it would help track the source of the instability. It didn't.
  • Manually cherry-picking commits, but it's not feasible for the scale of this branch.
The Core Question & Where I'm Looking for Help:
This feels less like a specific Git command issue and more like a flawed process. We need a better strategy for integrating large, complex features.
I've been researching how other ecosystems handle this. For instance, I was reading about the development lifecycle of a modular project documented here, which seems to avoid these "big bang" integration problems:
https://modhello.com/merge-fellas/
While it's a completely different domain (a game, I believe), the architectural principle of self-contained, independently testable modules before the final merge is very compelling.
Has anyone successfully implemented a similar "modular merge" or "feature-scaffold" strategy in a .NET/Azure DevOps environment to prevent this kind of unlimited shake? What are the best practices for de-risking a massive merge like the one we're facing in our Merge Fellas project?
Looking for strategic advice, not just a single command fix. Thanks!
Hello Hee!
Based on your inquiry, we understand that you require assistance with your .NET 7 project. We will be happy to help you.
Please be aware that you have reached the Microsoft credentials forum support. Our main focus is on Microsoft exams, which you can access through Browse Credentials | Microsoft Learn. Our exam forum community team is only able to assist with inquiries related to Microsoft Certification exams.
Additionally, in my continued effort to support you, I have identified the appropriate specialized support team that can assist you with the matter. With that being said, you can contact their Support team directly through:
We hope this information helps resolve your concern. If you require further assistance regarding your Certification Profile, please let us know.
Kindly,
Jimmy Llanos.
Last updated June 20, 2025 Views 18 Applies to:
