Not Able to Register for Exam
Hi!
I'm writing back regarding the same issue. I've been going back and forth with Pearson VUE to scheduled the exam but it seems like they do not have any of my information to proceed either by phone or online. They sent me back to you since if I understand correctly you will need to provide my information.
Can you please help me out with this?
Thank you,
Monica
It's for the exam
DA-100: Analyzing Data with Microsoft Power BI
Hello Monica,
Apologies for the inconvenienced this have caused you.
Furthermore, when registering for an exam, please make sure you’re using an InPrivate or Incognito browser. You may also try using other browsers preferably the newer version of Microsoft Edge which can be downloaded here: https://www.microsoft.com/en-us/edge.
Kindly also make sure to remove the occurrence of any non-English letters and replace them with Roman alphabets on the Certification profile (e.g. name, address). Signs and symbols should also be removed from the profile (like., \ ! @ # - etc.).
You may update your profile by logging in to your Microsoft Certification Dashboard then click “Edit Certification profile”.
If you encounter some issue, please provide us a PSR (Problem Steps Recorder), starting from the sign in page until the error message is shown on your screen.
You may upload the PSR file through the private message I initiated along with the requested information.
To access your private message, please refer on the image below or click on this link:
Darlene_J
Hello Monica,
Thank you for sending the requested details.
I have seen that there is a Non English character on your home address, hence I went over your profile and update it to Roman Alphabet.
With this, kindly try again to schedule your exam.
If same outcome persist, please send us a new PSR so we can continue troubleshooting you.
Darlene_J
Hello Monica,
Darlene_J
Last updated April 21, 2021 Views 18 Applies to:
