Technical Issue with "Deploy and Manage Microsoft Azure Arc-enabled Servers"
I have been trying to attend the "Deploy and Manage Microsoft Azure Arc-enabled Servers" applied skills test for the past three days, but I continue to face a technical issue. In the middle of working, I got this message(attached image) and then the lab was closed before I completed or pressed the submit button. It happened several times during lab.
Could you please assist me in resolving this technical problem? Your help would be greatly appreciated. Thank you.
Lab Instance ID/ref code :  45223875
Username:  **REMOVED**
URL of the lab:
 **REMOVED**
screenshot:
Date and time:  **REMOVED**
Koushik
***Personal Information deleted by the moderator. Please see the Microsoft’s Community Code of Conduct for more information on how you can protect your privacy**
Hi Koushik,
I understand how challenging it is when you encounter the same error message repeatedly after completing the verification process. Allow me to assist you on this matter.
Using the details supplied, I took the liberty to forward the concern to the Support team for a thorough evaluation and review.
You may send me a private message if you want to know the status of the escalation. At the same time, we will be updating this public post every 3-5 business days.
For your reference, I have provided your case ID via
private message.
Aileen_A02
Hi Koushik,
I hope you are doing well.
On behalf of my colleague @Aileen_A02, I took the liberty to check on your case. Please be advised that the team is still investigating the root cause of the issue you encountered. Your patience and cooperation are deeply appreciated.
You may send me a private message if you want to know the status of your case. At the same time, we will be updating this public post every 3-5 business days.
Warmly,
MLawrence_Y1
Hi Koushik,
Our team is still currently investigating the issue you encountered and we're waiting for a response. Meanwhile, it seems that the 72-hour cooldown period is over. Kindly let us know if you retake the assessment and if you encounter any issues.
We look forward to your response. Moreover, we will be updating this public post every 3-5 business days.
Aileen_A02
Hi Koushik,
We received an update, the "Create and manage model-driven apps with Power Apps and Dataverse" assessment is currently unavailable online. Our back-end team is actively working to restore the remaining topics.
Please refer to the sticky post for the latest updates on when this assessment will be back online. We are continuously updating it as soon as the assessment becomes available.
I look forward to your response. Please note that if no response is received after three business days, the case will be closed and locked. After the case is locked, we will no longer be able to respond. Thank you.
Best Regards,
Aileen_A02
Hi Koushik,
We have not received any update from you. This case will now be locked. Please note that once Private Messaging has been locked and closed, you cannot reply. If you need further assistance, please post a new question.
Aileen_A02
Last updated November 15, 2024 Views 80 Applies to:
