There was a problem processing your payment. Please try again.
Split from this thread.
I can't do two things:
I can't edit my certification profile, save & continue does nothing at all. (but my info is up to date..)
I can't schedule az 204 exam, because I receive this error after submitting my order: "There was a problem processing your payment. Please try again."
Tried different browsers, incognito modes, different exam locations and time...
I am trying to schedule 98-381 exam. After submitting my order it is showing "The payment was declined. Reason : Contact your credit card company or use a different credit card". I have used different credit cards as well but the final result is same.
Hi SUGUNAKAR,
Based from the error message you are getting, you were unable to complete the registration of your exam. Allow me to provide you further information and direct you to the correct department.
I would recommend you to please try the following recommendations below:
1.     Use the new MS Edge browser that you can download
here.
2.     Make sure to disable the Block all third party cookies function from the browser settings.
3.     Once done, please press F12 function key
4.     Once you see a Developer Tool window popping up on the screen, click on "Network Tab" and clear the session.
5.     Refresh the screen.
6.     Go to Microsoft Certification Dashboard then sign in with the Microsoft account and password associated with your certification.
7.     On Your Dashboard, click on Edit your certification profile
8.     Make sure to fill out all required fields. (Marked with asterisk *)
9.     Click Save and Continue.
10.  Go back to the Dashboard and click Schedule next exam button to select and register the exam.
If in case it did not work, I recommend for you to contact the testing vendor for assistance in completing the payment. You may reach their Support through the following contact details: Contact Pearson VUE.
I hope this helps.
Nhorjane
Last updated April 18, 2022 Views 82 Applies to:
